I can only sometimes click on some cells, but most of the time I can’t click on any cells.
Obsidian version: v1.5.3
Installer version: v1.4.16
Operating system: #1 SMP Thu Oct 5 21:02:42 UTC 2023 5.15.133.1-microsoft-standard-WSL2
Catalyst license: insider
Insider build toggle: on
Live preview: off
Plugins installed: 8
Plugins enabled: 0
I can still navigate into the table cells with the arrow keys.
I have a screen recording of the bug, but I can’t upload that here.
I’ve been dealing with the exact same issue since the new table core plugin rolled out. It’s very frustrating to have to change to source view to edit tables or use the arrow and tab keys to navigate cells in the editor. I only have this issue on Obsidian packages for Linux though. Other OSs like macOS work as intended in this regard.
Same issue here. I’m only facing this on a Debian distro – no issues in Windows or on my Fedora machine. I currently have to switch to the source mode to do anything, and word wrap doesn’t seem to work in that mode so it makes it pretty difficult to use.
I have the same issue. I tried the following steps to get rid of the problem, all with the same outcome:
Disable Advanced Tables community plug-in + restart Obidian
uninstall Advanced Tables community plug-in + restart Obsidian
disable all community plug-ins (Restricted Mode=ON) + restart Obsidian
uninstall debian package (with -purge option) + restart linux
Run 1.5.3 from AppImage - issue present
Run 1.4.16 from AppImage - issue absent
reinstalled .deb package - issue present
Tested all this with Sandbox vault as well, same results
I do not have any custom themes
Same as OP, my only option is editing in source mode = pita.
I have bound a hotkey for switching, but still
Debug info :
Installer version: v1.5.3
Operating system: #1 SMP PREEMPT_DYNAMIC Fri Jan 12 18:20:08 PST 2024 6.1.60-08594-g03a802b9a072
Plugins installed: 6
Plugins enabled: 5
1: Omnisearch v1.21.1
2: Tasks v6.0.0
3: Editing Toolbar v2.4.0
4: Shell commands v0.21.0
5: Mind Map v1.1.0
xxxxxx@penguin:~/downloads/obsidian$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
https://youtu.be/JVbqIE-dkIM shows a quick set of examples. Note that when I change to live preview I’m clicking each time the mouse pauses. When I click below the table the cursor starts there but text gets appended to the end of the table. When I add a new row, I can’t edit text except for in the final column (apparently). Let me know if you want to see me try anything else.
I’m using a Logitech MX Master 3S. Also, just realized I didn’t mention this earlier, but this is a VM (VMWare Workstation Pro). Obsidian works just fine on the host (Windows 11) but not in any Debian-based X11 VM it appears. I don’t have non-deb VMs to compare against, however. I’m willing to install one if you think it will help.
And yes, just downloaded latest AppImage to make sure the bug replicates, and it’s still there. Slightly different behavior at times, where I can click in the first column on one table but I couldn’t on another one, but overall most of the cells are not editable in the Live Preview.
I don’t have an extra machine to natively install Debian to test with. Also, even if I did, my use case doesn’t change where I need to use this VM for my job, and due to security reasons I can’t just use the version on my host system. If it helps I’m happy to open a separate bug request or forum post if you feel this needs to be handled elsewhere.
My request was to figure out if this is a problem of VMware (they don’t emulate some mouse events well?!?). If that’s the case you should file a bug report to them.
All these reports have in common the implicit or explicit use of a virtualization environment.
I again think that the virtualization layer is not passing all the mouse events from the host to the guest.
