- Position the cursor anywhere within a bulleted or numbered list, or a blockquote
- If you’re not in Vim’s normal mode, enter it by pressing Esc
- Press o or O to open a new line
The new line should be a part of the list/blockquote, ie. be prefixed with - , > or similar, just like if you had pressed Enter in insert mode (or non-Vim mode).
The new line is completely empty.
- Operating system: Windows 11
- Debug info:
Obsidian version: v1.0.3
Installer version: v1.0.3
Operating system: Windows 10 Pro 10.0.22621
Catalyst license: none
Legacy editor: off
Community theme: Minimal
Snippets enabled: 1
Plugins installed: 28
Plugins enabled: 26
1: Calendar v1.5.10
2: Tasks v1.18.1
3: Tracker v1.10.9
4: Better Word Count v0.8.1
5: Novel word count v2.9.1
6: Longform v2.0.0
7: Icon Folder v1.4.1
8: Daily Stats v1.0.4
9: Commander v0.3.0
10: Kindle Highlights v1.8.1
11: Automatically reveal active file v1.0.2
12: Focus Mode v1.11.4
13: Advanced Tables v0.17.3
14: Rollover Daily Todos v1.1.1
15: Minimal Theme Settings v6.1.0
16: Contextual Typography v2.2.4
17: Checklist v2.2.10
18: Style Settings v0.4.12
19: Pipe tricks v1.1.0
20: Auto Link Title v1.2.5
21: Custom File Explorer sorting v1.2.0
22: Github Publisher v4.5.1
23: Frontmatter Links v1.1.0
24: Waypoint v1.3.0
25: Daily Notes Viewer v0.2.1
26: Omnisearch v1.8.1
