This feature is very essential, I wonder that it’s not integrated yet, without it the graph is useless for tags.
+1
Googled to see if there was a community plugin or hidden setting for this, a bit disappointed it’s been ignored for so long. Hope we can get this implemented some day!
+1! would make the graph more powerful
Hello everyone! Today I found this thread, and realized that if this feature has not been done in 3 years, then you need to do it yourself. 2 hours of reverse engineering later, I wrote this plugin. I’m not sure if it will be approved, since it doesn’t use a public API, but you can check these 15 lines of code anyway and install the plugin manually
The plugin is approved, now it can be found in community plugins named “Nested tags graph”
That’s amazing!!!
Crazy that this hasn’t been implemented yet given how important making connections is for Obsidian. Would make tags way more useful than they are now.
Thank you so much man
awesome
really appreciate it!!!
idk if it makes sense to nitpick on this plugin. i am not sure if my expectations will raise any contradictions or unintended complications. lemme know what you think.
assume the following example of physics(assume kinematics) being taught at school and you get back to it later in life in game-development. ref.pics
Case1
with graph-nested-tags enabled
- note1 has #physics/school
- note2 has #physics/gamedev
thus, Case1 gets represented as (image) which is an useful layout. ie:
PHYSICS->
-> physics/school -> note1
-> physics/gamedev->note2
Case 2
incase the user saves his school notes using #school/physics instead of #physics/school as found earlier in case1
- note1 has #school/physics
- note2 has #gamedev/physics
the plugin outputs two different graphsimage:
SCHOOL->school/physics->note1
GAMEDEV->gamedev/physics->note2
comparing both cases, physics being a concept, it shouldn’t matter if it’s tagged school first or physics first #physics/school v/s #school/physics
both should be recognized in the nested tags system as it’s intuitive to expect them to get linked to other concepts, such as:
.../PHYSICS->
-> school/physics -> note1
-> gamedev/physics -> note2
[IGNORE] [IGNORE] [IGNORE]
explaining my case as template without physics example
Assume:
- Tag1 = physics
- subtagA = school
- subtagB = gamedev
Case1:
- note1 has #Tag1/subtagA
- note2 has #Tag1/subtagB
in the graph view it appears as follows:
TAG1->
->Tag1/subtagA-->Note1
->Tag1/subtagB-->Note2
Case2:
incase the user saves #subtagA/Tag1 rather than #Tag1/subtagA as found earlier in case1
- note1 has subtagA/Tag1
- note2 has subtagB/Tag1
it makes it out to be two separate graphs
SUBTAGa->subtagA/Tag1->note1
SUBTAGb->subtagB/Tag1->note2
but it’d be useful to have Case2 outputted as:
../TAG1->
->subtagA/Tag1->Note1
->subtagB/Tag1->Note2
+1 for this feature in Core.
+1, This is exactly what i’m looking for
+1, I don’t know why it doesn’t work like this in the first place
+1, same as others, great (and expected) feature
Ditto for me. I appreciate the plugin, but this should be a core feature. What is the point of nesting tags if they no longer exists as individual tags after that point?
would love to see this feature. thanks obsidian team for your work and time
Absolutely essential feature
I switched from Bear to Obsidian assuming this feature was part of the graph view. I joined this forum just to beg for this.
+1, must have for anybody who uses nested tags
