Urgent bug penalizing and strange
excuse me, could someone help me, I’m depressed, I just lost several years of work on Obsedian that was on my daily bill which is being dumped for no reason.
At first I wasn’t worried, I set the file recovery option to 30 days with an update every 5 minutes but it didn’t surprise me to find that all the snapshots had disappeared regardless the note I have for May 1st. 2024 4:42 a.m. as if everything had been reset
I’m depressed, I had my business ideas and everything in them
Since the folder has not been deleted but emptied, I cannot recover it from the trash and I do not have access to snapshots (because of a bug)
In addition it’s disturbing the file is empty when I open it but it has 224kb yet I don’t understand anything anymore, please help me it’s very important
(And yes I already made a backup but I lost my most important recent project)
Hello,
You didn’t provide much information so I am not sure how we can help.
Where is your vault stored? Are you using iclould/dropbox or similar services?
Can you post some screenshot of what you mean by this?
My safe is stored in my documents. I use through icloud or dropbox or similar services.
I copied/pasted my safe to avoid losing the data of this note, there are 224 kb on it while the note has been emptied of its contents.
If you a third-party sync or backup service:
  1. You need to make sure that that service is configured to store you notes locally on your computer.
  2. You can check if the service you use has a recent copy of the files you are misssing.
