Update mermaid.js from 11.4 to 11.5 or later to fix arrow rendering
Obsidian’s Mermaid.js renders undirected graphs as directed. This is fixed in Mermaid versions newer than 11.5.0, but Obsidian is using 11.4.1.
All of the following render incorrectly, as arrows instead of lines.
graph TD
	a --- b
graph LR
	a --- b
graph
	a --- b
flowchart TD
	a --- b
Yes
I expect to see a line between A and B with no arrows, which is what the Mermaid sandbox shows.
Versions of Mermaid.js up to (but not including) 11.5.0 have this bug.
The Mermaid PR at github com/mermaid-js/mermaid/pull/6093 (sorry, it doesn’t let me post links) indicates that it is 11.5.0 in which this is fixed.
On the Obsidian credits page I see Obsidian is using 11.4.1.
Obsidian version: v1.9.14
Installer version: v1.7.7
Operating system: #1 SMP PREEMPT_DYNAMIC Debian 6.12.48-1 (2025-09-20) 6.12.48+deb13-amd64
Language: es
Catalyst license: none
This is a known issue :blush:
(Obsidian updates its dependencies once in a while though… so it’ll probably be fixed at some point)
