A line between A and B without arrow tips. It’s called an “open link” by Mermaid.
I cant share the link to the Mermaid documentation.
Marmaid Documentation → “Syntax” → “Flowchart” → “An open link”
I see a link between A and B with an arrow head pointing towards B.
The rendered diagram is identical to the following code, it shouldn’t.
flowchart LR
A --> B
Obsidian version: v1.8.9
Installer version: v1.6.7
Operating system: Windows 11 Home 10.0.26100
Catalyst license: none
Expected result (screenshot from Mermaid.js documentation)
There was a change in how Obsidian renders mermaid fairly recently (not sure exact version) that seems to have brought this bug. It was the change that caused the nodes to have purple outlines.
This issue (#6289) has been marked as fixed on Mermaid as of three weeks ago from the date of this post and is present in the latest release ([email protected], commit efe218a)
Obsidian version: 1.12.7
Installer version: 1.12.4
Language: en-GB
Plugins installed: 3
Plugins enabled: 3
1: Iconize v2.14.7
2: Export Image plugin v2.4.4
3: Code Styler v1.1.7
In Obsidian for Windows 1.12.7, Mermaid flowchart links written as open links using --- are rendered with an arrowhead, visually the same as -->.
According to Mermaid flowchart syntax, --- should render as a plain line without an arrowhead, while --> should render as a line with an arrowhead.
Create a note containing the following Mermaid block:
flowchart LR
A(简单) --- B(关键)
The line is rendered with an arrowhead, as if the code were:
App: Obsidian desktop
Platform: Windows
Additional notes
This makes it difficult to create Mermaid diagrams where the relationship is meant to be undirected or non-directional. The issue appears to be with the built-in Mermaid rendering behavior rather than the Mermaid syntax itself.
