start a new note in Obsidian
insert the U+200E LEFT-TO-RIGHT MARK
write some RTL text after the mark
in a new line insert the U+200F RIGHT-TO-LEFT MARK
write some LTR text after the mark
now in a new line insert the U+061C ARABIC LETTER MARK
Here’s an exemple text: (make sure you add the invisible marks in the beginning of every line)
مرحبا
LTR text after ARABIC LETTER MARK
According to Right-to-left - Developer Documentation:
When editing a file, the
dirattribute is set tortlorltrper line on.cm-lineelements by detecting the first strongly directional character.
The LEFT-TO-RIGHT MARK and RIGHT-TO-LEFT MARK should (by definition) be treated like other strongly directional characters.
The RIGHT-TO-LEFT MARK and ARABIC LETTER MARK should be treated in the same way.
The LEFT-TO-RIGHT MARK and RIGHT-TO-LEFT MARK has no effect to the text direction, unlike ARABIC LETTER MARK and all other strongly directional characters. (See the screenshot)
Obsidian version: v1.6.3
Installer version: v1.6.3
Resolving this issue will let the user manually decide the text direction of each line. That’s very useful when dealing with a mix of both LTR and RTL languages within the same note.
The new automatic detection of text direction introduced in Obsidian 1.6 but unfortunately isn’t always good. In many cases, it becomes a real mess, for example if you make a bulleted list with both LTR and RTL text. That’s confirmed by many RTL users in this forum.
