We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
  1. open a note
  2. split the windows vertically or horizontally
  3. try to use the pen to adjust the width or heights of a note pane
Adjusting the pane size like when the mouse is used.
the boarder can be automatically highlighted when the pen is hovering or clicking on he boarder, but the adjusting icon will not show up and there is no way to adjust the size consequently.
  • Operating system: Win10, with Surface Pro 4 with a sytlus pen
  • Obsidian version: 0.12.2
Please, open a feature request.
Sorry for the disrupting.
I thought this use case(supporting Surface with pen) was covered by the Windows version. I don’t mean to increase your work load, honestly.
BTW I think the Surface with pen maybe a platform for testing the application scenarios where the touch screen or pen is considered.
