We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
I didn’t test the touch screen, but I think I does not help either. In order to adjust the size of the pane, such as the editor pane, search pane, backlink pane, the only possible solution now is to put aside the pen and connect and switch back to the mouse or touchpad. In case you are carrying only the screen and the pen with your for sharing ideas, that is really an embarrassing scene.
