When rebuilding or integrating a vault with excessive links and tags where only very few of the tags and links are useful, I sometimes replace all occurrences of [
, and #
with \[
, and \#
respectively. This increases the autocomplete effectiveness and performance as well as clearing the graph and tag pane so that I can manually remove the \
before the [
, and #
characters for the links and tags I want to revive. This unfortunately makes navigation very difficult.
Add a setting (w/ hotkey) to disable the ability of backslashes to escape brackets.
This could be helpful for cleaning up messes like the one I made in this image from a while back:
Also Relevant:
Thanks so much!
