I have searched the forum and help and am aware of the ability to use bacticks to add inline codeblock formatting. I am also aware of the ability to use backslashes to escape the subsequent character.
I am trying to disable all links and tags across a vault. I am aware of the technique of using search and replace to apply codeblock formatting or backslash escaping to all occurrences of [
, and #
within only links and tags. It works okay but I t requires some regex and is potentially destructive. My main issue is that of being able to effectively undo this disabling at some point either vault wide or on a note by note and occurrence by occurrence basis.
For more context, I am specifically doing this in order to reduce the chaos when trying to tame some of my older vaults and reintegrate as a single whole. Here’s a link to a relevant feature request I made: Toggle ability to disable links with backslash
Thanks!
