I’m somewhat used to writing in Atom. When I write, I often leave out things that need to be fixed later – missing references (REF), general todos (TODO), etc. Atom has a great plugin that collects all these (you can configure it what to collect) and then it lists them on a side pane with clickable links. Since these occur inline in the text, they are not “todo-s” in the usual bucket-listy kind of way but just part of the text (TODO ugly sentence, rewrite).
It would be really nice to see all TODO’s, REF’s, etc. of the active file in a side pane, with jumpable links.
I use search currently. Maybe it would be doable with tags as well, but I use tags for other things. The problem with search is that it is cumbersome, and when I’m working on a file, I’m not interested in TODOs in other things.
Maybe this is more like a plugin idea than a feature request. If so, please just move it.
