Darken background slider of BG Themes is right below the Presets dropdown menu (Presets Submenu). Faster and easier to use (removed the bg themes submenu).
Search layout adjustment in modals. When there is a highlight background (search results), this highlight background will be the same color of highlight in live preview mode. Highlighted foreground text will appear in black color (exactly like the display in live preview, source and reading modes).
You can centralize the heading callout title using |center] and align it to the right using |right]:
> [h1 to h6- + color|center] Your callout title
New Callouts
Line callouts (7 colors)
> [l-+ color] Your callout title
You can centralize the content using |center] or align right (|right]): > [l-+ color|center] Your callout title or > [l-+ color|right] Your callout title
@cameron I’m so glad you enjoyed the new concentration theme and callouts! I really appreciate you taking the time to leave a comment. It’s incredibly motivating and the feedback is truly valuable to me.
By the way, your video about the theme was fantastic! It was a huge source of inspiration for me. Thank you so much!
Can someone export there settings so i can import it easily. i am having a hard time setting it up… i tried the preset and it seems to only have effect on the menu but the note looks the same. the headings and everything are not colored. i tried turning on neon and outline… but still the headings are not colored. while writing # it shows the effects… i tried turning off all other plugins … still didnt change
@fred.joe3697 You shoud add a space after the heading text.
## Heading 2
###### Heading 6
Checking your image, no spaces. When you add `“#text” (this is a tag, not a heading).
By the way, your setting to darken the background only works for the MagicUser BG preset themes, so you can improve readability darken the background gradients.
Let me know if it will work for you, it is not that difficult to set up, but you should write the markdown syntax to see the neon heading format (otherwise is just plain text or a tag).
When you activate outline neon mode, it will be dominant over neon mode. If you just want neon, turn off outline neon mode. You are using both enabled, you can select one at a time.
i created a new vault and copied the appearance.json from there to my original vault and that fixed my issue…
i was installing so many plugins and tried out a lot of appearance plugins before . … may be that could have caused the note background to not change color when i tried different presets…
I meant add space before the text, but after the # . Just a quick note. I can’t edit my post. So I am writing this here. It was shown correctly on the mardown code (heading 2 and 6).
