Thank you for this update!
The toggle to hide header underline is exactly what I was looking for.
Have a great day.
Thank you for the update. Dark mode now works again on iOS.
Update
  • Outline pane scroll fixed on Mobile
    • Outline pane also recolors line when hovering over titles:
      QClKIebbPT oYgHIvc6Be
  • Mathjax/Latex fixes: larger and recolored $text$
  • Fixed codeblock tokens to match theme colors:
  • Flipped folder color: opened folder should be lighter, not the closed
  • Highlights recolored
    • Recolored light mode markdown ==highlights==
    • Recolored darkmode cursor dragged highlights to make it easier to see
    • Editor mode cursor dragged highlights actually highlight over text and codeblocks
      hC7nK57c3A 9L0Y8RWcDe
  • Style Settings toggle added to move heading hashes# above the text
    Obsidian_TM48tsZaGn tvhYo5Hvtn
Ah, great idea!
Hello @SlRvb!
I have a bug to report:
  • I’m using ITS + Style Settings.
  • Both are update to the latest version.
The screen below shows [Text Selection - Cursor Dragged Highlights] in edit mode vs. preview mode.
As we can see, in edit mode, the text selection color is making the text disappear. Everything is OK with preview mode and highlights (edit and preview mode).
A few important things:
  • This does not happen with default ITS;
  • I spend an hour changing my settings in SS trying to find the solution. Any other option uses the same color I use in [Text Selection];
  • I changed colors, but the result was the same;
  • I think is my fault, but I don’t know how to repair.
I hope someone could help to find why this is happening.
Thanks!
This is an update (18042021) about my previous post:
Changing to a color that is more transparent (I don’t know if this is the right term) “solved” the issue. I used #F9FF0036 instead of #FFFFB7.
@SlRvb, feel free to discard this bug. I’m sorry for the inconvenience.
Thanks!
Hello again @SlRvb!
First of all, thank you for developing ITS. There is no other theme that brings the amount of features as you do.
I’m having a great time using ITS + Style Settings to tweak the theme with a palette of colors that help me to deal with my monitor problems.
I’d like to suggest some parametrization related to Headers and Format
1. Define different colors to Headers
  • Available in EDIT mode;
  • Available in PREVIEW mode;
  • EDIT and PREVIEW mode uses the same customization.
Let you define individual colors to all headers:
H1
H2
H3
H4
H5
H6
2. Define different colors to Bold, italic and Strikethrough
Let you define individual colors to these 3 types of text:
  • Bold
  • Italic
  • Strikethrough
Why you need this?
  • I used Obsidian to study and I import many sources of information to Obsidian.
  • Inside Obsidian, I format and read a lot
  • After this, I generate my notes, backlinks and tags.
If I have more freedom to customize the appearance, I will have more pleasure to read and concentrate all information in Obsidian.
I hope you like my suggestions. Thanks for reading this!
Felipe
Yeah, I’ve been meaning to eventually add support for different colored Headings in the Style Settings. I’ll definitely try to get #2 done as well at some point.
Great suggestions! I’m glad you enjoy my theme :heart:.
Thanks @SlRvb!
Any feature that brings more customization to ITS will be more than welcome.
If don’t mind I will post more suggestions for ITS to your analysis and appreciation.
Thanks for your time! Have a great day.
Definitely post more if you have them, I’ll try my best to see if I can include it in the theme.
Update
Update
Plugin Support
Style Settings
  • Settings have been rearranged
  • Specific Heading Adjustments
    • Preview/Editor
    • Fonts
    • Colors
    • Sizes
  • Bullet Lists
    • Adjustable bullet line size
    • Multi colored bullets up to 6 subbullets for preview mode
    • Adjustable colors for multicolored bullets for preview mode
Adjustable Strikethrough/Bold/etc coming soon
updated!!! thanks @SIRvb
Thanks @SlRvb for letting me give some suggestions!
You can count on me to bring more insights for ITS.
These past days I was stuck at work but now I’m back and using ITS.
Wow. These past two updates were amazing!!!
Every update I makes ITS more powerful. I’m gonna spend the weekend playing with the new settings. I have a lot ground to cover.
Thank you @SlRvb for the spectacular theme. The Specific Heading Adjustments and Bullets Lists. What you did is much better than my suggestions.
—> Thanks for not forgetting!
This theme is just amazing :heart:
Thanks for the continuous work on it!
Hello @SlRvb !
I think I found some issues on Specific View Headings Changes - Heading Size
There are 3 issues:
1. H1 vs H6 - EDITOR MODE + PREVIEW MODE
2. H2 vs H4 vs H5 - EDITOR MODE + PREVIEW MODE
  • H2 scroll bar is affecting (moving) H4 and H5 and H2
  • H4 scroll bar is not affecting (moving) H4
  • H5 scroll bar is not affecting (moving) H5
  • H4 and H5 scroll bar are not affecting (moving) H2
3. H1 PREVIEW - Scroll bar ratio of increment
  • It’s very difficult to see but if you compare H1P to the others, looks like that the value is different;
  • Might be an issue, I don’t know but I felt right to comment.
→ Everything is OK with H3 PREVIEW and H3 EDIT
Let me know if you need some specific test.
Thanks!
Hello again @SlRvb !
I think I found issues on Specific View Headings Changes - Heading Color
HEADER COLORS in PREVIEW MODE vs EDIT MODE
  • This occurs in H4, H5 and H6 only
  • EDIT MODE colors are not being applied
  • PREVIEW MODE colors are being applied in EDIT MODE.
Everything is OK with H1, H2 and H3
Thanks!
Update
Style Settings
  • Auto collapse Specific settings
  • Fixed Specific Headers not applying correctly
    qIKx9iEaXv Obsidian_npWFTJVtMx
  • Adjustable Italics, Bold, and Strikethrough
    • Preview/Edit mode
    • Fonts
    • Colors
@SlRvb, Thanks for this update!
Updating now!!!
Is this the Codeblock Copy plug-in?
Thanks!
