@henrique: I don’t mind where you post it, I am not a moderator and am not criticizing you. It just strikes me as odd that you say the comment is specifically for Blue Topaz when you mention PhraseExpress that is not linked to BT in any way, and “to select the type of note” could be used in any theme.
If I misunderstand I apologize, and if you think your comment belongs here that’s fine by me. No hard feelings, no criticism.
Hi there, your theme is amazing.
I have one big issue. I face problems in selecting text from quotes. Please fix this. And thanks for creating this amazing theme.
@jay_ed: that is not a bug but probably with a few things to make Edit more pleasant to read. I encountered the same, and used to manually remove the >, which then allows selecting text.
I eventually found and installed the Hotkey++ key which lets you toggle the blockquote character > with Ctrl+< or Cmd+Shift+<. With that it is easy to remove/put back in that character.
There is also a toggle for the ! for embeds/transclusions.
Unfortunately, yes, it’s caused by the theme. Thank you for your reporting. I was too busy to fix that. Sorry about that. And I will fix it in the next version.
@Klaas@ImBK@ducklord@gnatan@nabhan
Thank you for liking BT. The new version has been released. I have fixed all reported bugs. Please update and enjoy!
