Fixed. Please update the theme.
There’s a neat new feature that I think came with an update to this theme. When I hover over an indented list item it shows a colorful elbow shaped line that shows just what parent list item it is attached to. This is great.
Is there a particular setting anywhere I can use to change the color of just that line? I’m not sure what it would be called in order to locate it.
After a bit of trial and error I figured out that it currently uses the ‘theme color’, as changing that changes the color of the line.
Thank you.
Using this one only for the coloured file explorer and couldn’t find the same feature as a standalone snippet.
Feature request: Any way to add a toggle to style settings to internal links formatted in bold similar to the ITS theme?
Can any one help me with few of my issue!?
I am unable to make following commands work in my vault
ad-col2/3
ad-flex
I just started using theme and found a demo vault in english but, It is in previous version and few commands doesn’t work now.
Or are there any CSS i should be using?
Hey, love the theme but I can’t use local files as background images at all. I followed the syntax exactly but it isn’t working. Is there any way you can just type: [[image.png]] from my vault in this field for local images instead of having to exit Obsidian to file explorer to get the file path? When i try to do that, the slashes are \ instead of / and even when I correct that nothing happens. I don’t want to rely on external web pages for my vault.
facing the same problem with the first point, have you found any solution??
I am still having this problem. I can’t figure this out, if anyone could help it would be appreciated. I don’t want to rely on external links for my workspace backgrounds.
I posted a question about this great theme here: Blue Topaz: I can't find the settings for some colors
I don’t know if I should have posted it on this thread or anywhere else. Sorry if that isn’t its place.
