The help vaulte
We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
The help vault in the program in Windows is very usefull why don’t do the same thing in the app Android
I hop you do this property to learn more about using the app in the best way
