- Google searches
- Searching https://www.reddit.com/r/ObsidianMD/
- Searching the forum
I suspect since I’m new to obsidian I’m not using the correct terminology.
I have tags and links in the metadata at the top of my file; however, those tags/links don’t show up in the tooling on the side. Is there a setting, plugin, or a convention that exposes the metadata so links/tags are respected?
Example
The tag #journal/daily will only show up in the sidebar/graph if I move it out of the metadata block. The links will only show up in the sidebar/graph if I move them out of the metadata block
template: [[Daily Journal Template]]
week: [[2021-08-W32]]
tags: #journal/daily
# Daily Jornal - 2021-08-01
more text...
