Tabs pulled to sidebar do not show pin icon
If a tab is pulled to the sidebar and is pinned their, the tab in the sidebar does not show a pin symbol.
I would expect to see a pin symbol next to the tab name.
Alternatively I could imagine to give tabs in the sidebar a „pinned“ status automatically as I do not see any point in having floating tabs in the sidebar.
Also I think there is a certain conceptual overlap between bookmarks and pinned tabs in the sidebar, the only difference being that tabs in the sidebar will always open there and allow for the classic pane workflow of opening links to the right (PLEASE keep that, I think this is crucial to many many powerusers workflows :folded_hands: )
There is no pin symbol.
Operating system: ios 16.4.1 (Apple iPad)
Obsidian version: 1.4.5 (102)
API version: v1.3.0
Catalyst license: insider
Legacy editor: off
Community theme: AnuPpuccin v1.4.2
Snippets enabled: 1
Plugins installed: 8
Plugins enabled: 4
1: Natural Language Dates v0.6.1
2: Tasks v1.25.0
3: Style Settings v1.0.3
4: Readwise Official v2.0.1
I can’t reproduce.
When you submit a bug report, you are being asked to try in the sandbox vault or in a vault with default theme and restricted mode on, have you tried? Can you post a screenshot?
Just doublechecked, yes I can reproduce it with default theme and restricted mode. Applies only to iPad version though, not for desktop, I see the pin symbols there.
See screenshot, this is how it looks after I pinned “Test Note 2” - looking the same as unpinned.
How did you pull tabs to the sidebar on mobile?
I’m not sure how they did it, but sometimes it just happens.
https://forum.obsidian.md/t/mobile-make-it-possible-to-move-a-note-from-to-the-sidebars-without-mouse/43994/5?u=cawlinteffid
