Tables with links inside not showing correct width in source mode
Switch to source mode.
Copy-paste the following markdown:
| column A | column B |
| blabla   |          |
| [[link]]     |          |
The column width is respected when the [[ and ]] of the link are visible - if it is selected or the cursor is inside the link:
Снимок экрана 2023-08-02 в 14.21.28
Снимок экрана 2023-08-02 в 14.21.15
Did you follow the troubleshooting guide? Yes
The column width would be respected regardless of the disappearing [[ and ]].
If the cursor is outside, the width is being shrinked by 4 - the number of the “disappearing” characters (the white bar is the cursor):
Снимок экрана 2023-08-02 в 14.21.07
Obsidian version: v1.4.2
Installer version: v1.3.5
Operating system: Darwin Kernel Version 20.6.0: Thu Jul 6 22:12:47 PDT 2023; root:xnu-7195.141.49.702.12~1/RELEASE_X86_64 20.6.0
Catalyst license: supporter
Insider build toggle: on
Legacy editor: off
no sorry, I don’t consider this a bug. Open a feature request.
