(Initially submitted as a bug)
We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
Copy-paste the following markdown:
| column A | column B |
| blabla | |
| [[link]] | |
The column width is respected when the [[
and ]]
of the link are visible - if it is selected or the cursor is inside the link:
If the cursor is outside, the width is being shrinked by 4 - the number of the “disappearing” characters (the white bar is the cursor):
There should be an adjustment mechanism so that the column width would be respected regardless of the disappearing [[
and ]]
None
