I want to be able to create an internal link by clicking once within the outgoing links tab under unlinked mentions. I believe this is how the unlinked mentions area used to work but now a hidden drop down menu adjacent to each item in the list has been added which must be opened on each item to find the link option.
Add a setting under files and links that causes that link button in the dropdown menu on each item to always be available
Open the drop down menu on each item I wish to link and then click on the link option
(I know it’s just 1 extra click per link but the drop down menu is tedious to find and I feel it really slows down my workflow as I use more than 1 link per sentence usually)
