Show existing values in Properties view
Currently, in “All properties” view, it is possible to see properties that are present in a vault, along with amount of notes that have this property.
There is, however, no simple way to find out which values each property has, and how many files has said property.
It is possible to find notes that has property with particular value by ["property":value] search request.
But that is inconvenient since you have to type each property and each value with no suggestions from search query field.
Each line in “All properties” view can become a foldable list, similar to nested tags view.
Child lines for each property can be certain value that this property is assigned, with amount of notes that have that property with that value calculated as well.
Clicking on property value can trigger search for notes with this property and value using ["property":value] query.
Maybe, there can also be new property types implemented: “Single select” and “Multiple select” that can have limited set of possible values configured from settings or “All properties” view.
Maybe, it also makes sense for user to be able to disable that “show me property values” feature per property, for several reasons.
For example, for ‘aliases’ property it’s going to be a mess and probably such aggregation would be pointless in most situations, and ui is going to be overloaded.
And for ‘tags’ property, it’s going to be similar/identical to “Tags view” anyway.
Related feature requests
help - List or table of all properties and values
feature request - Properties search improvement: Value selection as with tag search
+1 for this Feature Request, really miss it…
Workaround by @holroy:
Can’t believe this request didn’t get any traction! Without property values being shown in the All properties pane, properties, as a whole, are half as useful as they could be…
In a similar vein:
Properties is now a core plugin with the requested feature :grinning_face: . Good starting point, not something that is very very easy to help manage all tags / property values but a good start.
+1 for this feature request. This is a must have feature.
+1 for this feature! Please make Properties view more like Tags view. :slight_smile:
and as an addition:
  • property search field should also display property values
  • possibility to rename property value across the vault
Please advise whether it is possible to use Bases as a workaround to achieve a result similar to that provided by the Dataview code I referred to in my first message:
Or Bases can only display the files themselves?
At the moment, I have a separate file for recording the values of all Properties, but I didn’t keep it from the very beginning, and sometimes I remove or rename something, and it doesn’t show up anywhere (keeping a changelog for this document seems too… too absurd, I think…). The document only displays the values that I am currently using.
And to keep the vault clean, it would be very useful to be able to display all values, not just the current ones that were entered manually.
