Settings for Audio Recorder Core Plugin
There are no settings for the Audio Recorder Plugin, which limits the use cases of an important feature.
Input selection and a toggle for background noise removal (which is seemingly always on), would useful initial additions to the plugin which could resolve a lot of users needs, or at least allow for more workarounds.
This would also allow for embedded creative uses, such as capturing musical ideas or ambient noise recordings without having to use a separate application.
Hard agree. If we could just get the raw audio, this could be very powerful tool for capturing and organizing musical ideas over time
I use obsidian for lyrics, I’d like to record my demos as a link in the lyrics md file. The audio fidelity is not feasible (Android) to use the inbuilt recorder. I have to manually import audio which is not conducive to creative flow.
I believe the same is true on windows 10 but I rarely use obsidian on windows so I’m not certain (on vacation so PC not present to test that it’s not a poor quality microphone problem). I haven’t tried on Linux/Ubuntu.
Use a better audio system that can select between different mics or something… I don’t necessarily understand the cause of the low quality.
I am currently recording audio with Samsung voice memo, using Samsung file manager to copy to obsidian directory, then adding an inline link to the audio file.
Same problem noted for iOS. I think this request is closed, though.
Samsung voice recorder
Obsidian audio recorder
The mic was a little farther away for this than I usually record but it shows the issue pretty clearly that there is some additional compression causing issues with fading in or out.
Agree, I’m trying to switch out of Samsung Notes for demoing, Obsidian seems perfect except the audio is unusable for music.
donmccurdy has made a brilliant plugin called Field Recorder (installable currently via BRAT).
This has resolved my key issues with the Audio Recorder plugin and may be helpful for others on this thread - thank you for your work, Don!
I still hope features like these could be included in the core plugin in future so this is more accessible.
