tang
May 27, 2020, 11:58pm
1
I’d like to be able to specify the indent width inside the markdown editor. I type a deeply nested lists with very short items and it ends up very hard to tell what indent level I’m at.
The relevant css class seems to be .HyperMD-list-line, but it looks like obsidian adds an absolute padding-left, which doesn’t seem user-configurable.
Many thanks! Awesome app!
I kinda got it to work with this css
.cm-hmd-list-indent > .cm-tab {
margin-left: 20px;
(don’t really know how it works, just copied a chunk I found when searching for HyperMD-list-line)
Problem now is the lines that are wrapped around have weird indent and I don’t know how to fix. Similar issue to this Indent wrapped lines within nested lists in edit more
Edit: After switching from tabs to spaces for lists, the css no longer works
a_m
January 17, 2021, 12:31am
3
Whoa, this worked! I have no idea how because I can’t even find these class names being used in the html.
dorus
January 3, 2022, 8:44am
4
Old post, but for those who find this via google debugging (like me)
While using Obsidian, if you press CTRL-SHIFT-I (option-cmd-i for mac) then it will bring up the developer window.
See more: Getting comfortable with Obsidian CSS
dorus
January 3, 2022, 8:57am
5
Note: the solution posted here does not seem to work for me. I had to edit the solution in this post: How to make list indents deeper in editor mode? - #4 by ishgunacar
To get:
.HyperMD-list-line.HyperMD-list-line-1 {
padding-left: 20px !important;
.HyperMD-list-line.HyperMD-list-line-2 {
padding-left: 50px !important;
.HyperMD-list-line.HyperMD-list-line-3 {
padding-left: 80px !important;
.HyperMD-list-line.HyperMD-list-line-4{
padding-left: 110px !important;
.HyperMD-list-line.HyperMD-list-line-5 {
padding-left: 140px !important;
.HyperMD-list-line.HyperMD-list-line-6 {
padding-left: 170px !important;
.HyperMD-list-line.HyperMD-list-line-7 {
padding-left: 200px !important;
.HyperMD-list-line.HyperMD-list-line-8{
padding-left: 230px !important;
Works with live preview too (very happy to see that feature btw!)
I pasted this code and it works perfectly, but when I quit the application my modifications to app.css go away. How do I make my changes permanent?
You probably need CSS snippets
