Scrolling long notes, scroll abruptly stops in between
Platform
iOS
Obsidian Mobile version: v1.4.2 and earlier
When I swipe down on a longer note on iPad, every few seconds the scroll movement stops abruptly.
Default theme, CSS deactivated, restricted mode on. Obsidian was killed and restarted before the test.
In this example I used a very long note to demonstrate, but it also happens with shorter notes.
Screenrecording:
Related bug report: Tapping iOS status bar sometimes only scrolls partway to top
Confirmed.
I’ve never noticed it before because I tend to “refresh” the scroll with repeated swipes instead of waiting for it to stop.
additional info: There was an update some weeks ago which improved the rendering of markdown elements when scrolling fast. If I remember correctly, this improved the “abrupt-scroll-stop” behavior a lot.
I don’t think we are gonna do much more beyond that. This happens because the Live Preview is computed as you scroll.
I think a user doesn’t mind when the computation happens slow, but when the scrolling stops constantly, it feels broken.
A good workaround might be if the scrolling keeps going, and computing happens with a delay.
I think the issue is that Obsidian doesn’t know how far you can scroll until you’ve scrolled. It’s an interesting case for competing priorities, though. I also get caught by this behavior occasionally.
Unfortunately, I can confirm this problem on Android. Its effect in some cases prevents you from ever seeing the bottom of the note. I doubt it’s a rendering problem, as described, because of rapid scrolling, as the problem exists consistently with slow scrolling as well. Reloading the Obsidian sometimes will help you, as you can scroll either fast or slow and it will work as expected. The problem always returns after a while though.
This happens for me on both iPad and android.
this happens to me when scrolling to the top of a long note on Android
This one is a real pain, I would personally not tag as “minor” something I run into every single day (which means many more will too). It happens even with not-so-long notes. If there’s anything you guys can do to prioritize this, you have my vote!
I honestly think that pretty much every mobile user (at least iOS) is affected. It happens on my iPhone, iPad and my wife’s iPhone.
Sadly the problem occasionally pops up on my desktop as of late, especially in live preview mode. Seems to get stuck at a certain point of the note and no matter which way you scroll, it snaps back to the same spot. With the desktop, when this happens it often looks like it gets hung up on a markdown element, like links, image links, or the front matter at the top of the note. Perhaps this is a clue as to what is tripping up the scrolling on all devices. Sometimes switching to source mode helps but not always, yet reloading Obsidian altogether does seem to fix the problem for a while.
Experiencing this on macOS Sonoma. Really makes Obsidian feel broken given how smooth scrolling is on other apps, especially with a 120Hz screen. You’re zipping around, and then scroll something in Obsidian and just sludge or complete stop.
Please, post a screen recording of this happening in the sandbox vault and attach a copy of the file where this happens. Thanks.
I’ve noticed this happens on my iCloud vaults but not on my Obsidian Sync vaults. @chrsle are you using iCloud to sync your vault?
Issue is still present for me on my iPhone
I kind of found a way around this by toggling edit/preview mode on the top right whenever I know it is a large document I’m going to be scrolling. Until this is fixed, this is great.
To clarify what @axmag said, the problem seems to not happen in Reading View. I didn’t test much, but it looks like the iOS’s “tap to go to top” gesture also works correctly in Reading View ([Bug] Tapping iOS status bar sometimes only scrolls partway to top)
100% agree this is a major issue. I cannot scroll any note without this stopping me in my tracks and re-attempting a scroll multiple times before getting to the where I need to
@WhiteNoise Is there a good email address I can send a screen recording to?
FWIW I noticed I kept on re-scrolling over DataView and it’s worth mentioning I have a few DV queries on that same note… not sure if that is a relevant factor in the scroll challenge.
