To solve this problem I have tested the 13900K+3090, 7950x+4090, and 7950x3d+4090, and there is a serious issue with Canvas performance. No configuration can smoothly run a Canvas card with 26,000 characters of content, we can replace the text cards in the canvas with file cards, and then we can edit the cards in the markdown interface. Although writing too much will also cause lag in markdown editing, it is much better than in the canvas.
Pair with GitHub - slnsys/obsidian-canvas2document: Plugin for Obsidian to convert a complete Canvas to a long form document · GitHub to automatically convert canvas replacement cards into markdown files. Instructions for use:
- first, use Canvas2Document to convert all cards in the canvas file into md files.
- Then use this Python script to generate a modified version of the canvas file, replacing cards with markdown files. It also enables one-way updates; cards added in the modified version can be converted into md files and replaced, and cards added in the original will also be synchronized and updated in the modified version, converting into md files.This script, in theory, should not modify the original version of the canvas file.
import json
import os
def find_obsidian_root(current_dir):
# Search upwards from the current directory until the root directory containing the .obsidian folder is found
while True:
if os.path.exists(os.path.join(current_dir, '.obsidian')):
return current_dir
# Get the parent directory of the current directory
current_dir = os.path.dirname(current_dir)
# Stop searching if the root directory is reached
if current_dir == os.path.dirname(current_dir):
raise FileNotFoundError("Could not find the root directory containing the .obsidian folder")
def load_canvas_data(file_path):
with open(file_path, 'r', encoding='utf-8') as file:
return json.load(file)
def save_canvas_data(file_path, data):
with open(file_path, 'w', encoding='utf-8') as file:
json.dump(data, file, ensure_ascii=False, indent=4)
def update_modified_canvas_with_new_nodes(original_canvas, modified_canvas, base_path, relative_base_path, obsidian_root):
modified_node_ids = {node["id"] for node in modified_canvas.get("nodes", [])}
for node in original_canvas.get("nodes", []):
if node["id"] not in modified_node_ids:
print(f"Syncing new node: {node}")
if node.get("type") == "text":
node_id = node["id"]
new_file_path = os.path.join(base_path, f"newdoc-node_{node_id}_fromCanvas.md").replace("\\", "/")
# Create the markdown file and copy content if it does not exist
if not os.path.exists(new_file_path):
with open(new_file_path, 'w', encoding='utf-8') as md_file:
md_file.write(node["text"])
node["type"] = "file"
node["file"] = os.path.relpath(new_file_path, obsidian_root).replace("\\", "/")
del node["text"]
print(f"Synced node: {node}")
modified_canvas["nodes"].append(node)
def replace_canvas_content():
# Get the directory of the script
script_dir = os.path.dirname(os.path.abspath(__file__))
print(f"Script directory: {script_dir}")
# Find the root directory containing the .obsidian folder
obsidian_root = find_obsidian_root(script_dir)
print(f"Found .obsidian root directory: {obsidian_root}")
# Get all .canvas files in the script directory
canvas_files = [f for f in os.listdir(script_dir) if f.endswith('.canvas') and not f.endswith('_modified.canvas')]
print(f"Found .canvas files: {canvas_files}")
for canvas_file in canvas_files:
modified_canvas_file = canvas_file.replace('.canvas', '_modified.canvas')
# Skip processing if the modified file exists
if os.path.exists(os.path.join(script_dir, modified_canvas_file)):
print(f"Found modified file: {modified_canvas_file}, skipping {canvas_file}")
continue
print(f"\nProcessing file: {canvas_file}")
canvas_file_path = os.path.join(script_dir, canvas_file).replace("\\", "/")
base_name = os.path.splitext(canvas_file)[0]
base_path = os.path.join(script_dir, f"{base_name}_canvas2doc-data").replace("\\", "/")
# Skip processing if the corresponding folder does not exist
if not os.path.exists(base_path):
print(f"Warning: Folder {base_path} does not exist, skipping {canvas_file}")
continue
# Read the contents of the canvas file
canvas_data = load_canvas_data(canvas_file_path)
print(f"Read file content: {canvas_data}")
# Calculate the relative path
relative_base_path = os.path.relpath(base_path, obsidian_root).replace("\\", "/")
print(f"Relative folder path: {relative_base_path}")
# Iterate through each node in the canvas file and replace content
for node in canvas_data.get("nodes", []):
print(f"Processing node: {node}")
# Delete the original "text" field
del node["text"]
print(f"Modified node: {node}")
# Save the modified content back to a new canvas file
modified_canvas_file_path = os.path.join(script_dir, modified_canvas_file).replace("\\", "/")
save_canvas_data(modified_canvas_file_path, canvas_data)
print(f"Content successfully replaced and saved to: {modified_canvas_file_path}")
# Process all _modified.canvas files
modified_canvas_files = [f for f in os.listdir(script_dir) if f.endswith('_modified.canvas')]
for modified_canvas_file in modified_canvas_files:
print(f"\nProcessing modified file: {modified_canvas_file}")
base_name = modified_canvas_file.replace('_modified.canvas', '')
original_canvas_file_path = os.path.join(script_dir, f"{base_name}.canvas").replace("\\", "/")
# Read the contents of the modified canvas file
modified_canvas_data = load_canvas_data(modified_canvas_file_path)
original_canvas_data = load_canvas_data(original_canvas_file_path)
print(f"Read file content: {modified_canvas_data}")
# Sync new nodes
update_modified_canvas_with_new_nodes(original_canvas_data, modified_canvas_data, base_path, relative_base_path, obsidian_root)
# Iterate through each node in the modified canvas file and replace content
for node in modified_canvas_data.get("nodes", []):
# Write the text content to a new markdown file
del node["text"]
# Save the modified content back to the modified canvas file
save_canvas_data(modified_canvas_file_path, modified_canvas_data)
# Run the script
