Replace with an empty field does not work via keyboard shortcut
  • Open the sandbox vault, and in any note, find a string to remove (i.e. replace with nothing)
    • I tend to copy the string first so it shows automatically in Find/Replace. I’m not sure how much that affects things.
  • Invoke the Find/Replace feature.
  • Adding or pasting your string to the Find field, if it isn’t there already.
  • Leave the Replace field blank.
  • Press Enter to trigger the Replace action.
Y
The found instance of the search term should be replaced with nothing, i.e. deleted.
The found instance remains unchanged, and the selection moves to the next instance.
Obsidian version: v1.8.9
Installer version: v1.7.7
Operating system: Darwin Kernel Version 24.2.0: Fri Dec 6 18:40:14 PST 2024; root:xnu-11215.61.5~2/RELEASE_ARM64_T8103 24.2.0
Catalyst license: supporter
Insider build toggle: on
  • The replace action does work if the button is clicked instead.
  • Using enter does work if there’s text in the Replace field.
  • I know this is similar to a report from 2023, but that was for the “replace all” keyboard shortcut, which I haven’t tested.
ok, thank you
I’m affected by this as well. I always try to use key bindings because clicking around with the mouse is quite strenuous due to my disability.
