"Replace all" keyboard shortcut does not work when replace field is blank (Mac OS)
When using the keyboard shortcut to Replace all when the Replace field is left blank (i.e., to delete all occurrences of the text in the Find field), nothing happens.
  • Activate the command Search & replace in current file
  • Enter text in Find field
  • Leave Replace field blank
  • Press option + command + enter
  • Observe no changes
I expect the text entered in the `Find` field to be deleted when leaving the `Replace` field blank. It works when clicking the button, but not when using the keyboard shortcut.
Nothing happens.
Obsidian version: v1.4.14
Installer version: v1.4.13
Operating system: Darwin Kernel Version 22.6.0: Fri Sep 15 13:41:28 PDT 2023; root:xnu-8796.141.3.700.8~1/RELEASE_ARM64_T6000 22.6.0
Catalyst license: supporter
Insider build toggle: on
Legacy editor: off
Plugins installed: 0
Plugins enabled: 0
thanks
