I have the same exact issue outlined here, and the solution outlined here does not solve it, maybe it broke again?
I’m running the 1.9.1 beta.
This is a quality of life bug but really annoying in bases because it clutters the list of property fields with unused items when I search.
Subject: Need Help Deleting Properties from Auto-populated Dropdown
Hi Obsidian Community!
I’m running into an issue with the auto-populated dropdown for properties in Obsidian, and I was wondering if anyone here has a solution.
The Problem
When I’m adding new properties, Obsidian suggests a dropdown list that seems to be auto-populated based on previous entries. I can see these properties when I click on “View All Properties,” but I can’t figure out how to remove them permanently from the list.
What I’ve Tried
I tried to resolve this by opening the types.json file in VS Code. I can see the properties that I’ve created in this file, and when I add new ones, they do show up here. However, there are other properties that appear in the “View All Properties” list that are not in this types.json file.
Specific Issue
In particular, I’m trying to delete the property link that I created a while ago. I want to use link(s) instead. When I type “lin” and press “Enter,” it defaults to link, not link(s), which is not what I want.
Questions
- How can I permanently delete a property from the auto-populated dropdown list?
- Is there a specific file other than
types.jsonwhere these properties are stored?
Any help would be greatly appreciated!
Thank you in advance! ![]()
