YKYK
January 15, 2024, 5:50am
1
I did search and I found this topic https://forum.obsidian.md/t/how-to-bind-ctrl-h-to-backspace/30935
It is just as same as what I’m searching, but no one replies and it’s closed.
Finally, I found a solution. I’m afraid it’s only for Win 11.
unbind the hotkeys
binding (Setting → Hotkeys → Search & replace in current file
Install PowerToys
Go to Keyboard Manager → Remap a shortcut
Add shortcut, like “Select”: Ctrl (Left) + H “To send”: Backspace “Target app”: obsidian
Then it works and I’m satisfied for now.
I hope it will be helpful for someone.
I would like to use Ctrl+h as Backspace everywhere . I’m glad you’ve found a solution for Windows. On Arch+AwesomeWM, I’ve tried the following:
Change the GTK key theme as described in keyboard shortcuts - ctrl+h as Backspace in linux GUI apps - Super User (But Obsidian is not GTK)
Map with xbindkeys based on this thread, but it didn’t work and I didn’t investigate further:
How do I change the keyboard map for Backspace? - Ask Ubuntu
Now I’m trying out vim-anywhere as a different approach. You can map it to a keybinding to open Vim in any text-editing field and use your Vim configuration for editing.
(Here’s my branch with Vim-in-terminal support )
