Problems encountered when modifying unordered lists styles with CSS
I hope to achieve the following effect by modifying the style of unordered lists through CSS fragments.
I tried the following answer to this question. The code is as follows
:root {
/*  --bullet-new-color: Orange; */
 --bullet-new-color: rgb(89,89,89);
.markdown-source-view.mod-cm6 .HyperMD-list-line-1 .list-bullet:after {
/* Bullet */
	height: 5px;
	width: 5px;
	border-radius: 50%;
	background-color: var(--bullet-new-color);
.markdown-source-view.mod-cm6 .HyperMD-list-line-2 .list-bullet:after {
/* Dash */
	height: 1px;
	width: 7px;
	border-radius: 0%;
.markdown-source-view.mod-cm6 .HyperMD-list-line-3 .list-bullet:after {
/* Hollow Bullet */
	height: 4px;
	width: 4px;
	background-color: Transparent;
	border-color: var(--bullet-new-color);
	border-style: solid;
	border-radius: 50%;
	border-width: 1px;
.markdown-source-view.mod-cm6 .HyperMD-list-line-4 .list-bullet:after {
/* Solid Square */
	height: 5px;
	width: 5px;
	border-radius: 0%;
.markdown-source-view.mod-cm6 .HyperMD-list-line-5 .list-bullet:after {
/* Dash */
	height: 1px;
	width: 7px;
	border-radius: 0%;
.markdown-source-view.mod-cm6 .HyperMD-list-line-6 .list-bullet:after {
/* Hollow Square */
	height: 4px;
	width: 4px;
	border-radius: 0%;
	border-width: 1px;
.markdown-source-view.mod-cm6 .HyperMD-list-line-7 .list-bullet:after {
/* Small Bullet */
	height: 2px;
	width: 2px;
	border-radius: 50%;
This code can complete the style modification in editing mode, but it will no longer work when switching to reading mode.
I want to ask how to modify the code to achieve the same effect in reading mode.
Thank you.
Hi,
Same here, I tried inspecting the CSS to see if I could make out which CSS elements to modify, but got lost.
This is what the code of the linked post renders (I’m using the default theme in dark mode), with left pane being source, middle is live preview and right is reading mode:
Eventually I would also like to change the ordered lists to use 1, 2, 3… then a, b, c… then i, ii, iii… etc. Both in live preview and reading mode. And I’m guessing that the properties (border and background) used in the code above will not help, but rather something like list-style-type.
Hey :sailboat:
This will cover all 7 levels in reading-mode + edit-mode:
SCREENSHOT (reading-mode)
CSS
/* LEVEL 1 */
.markdown-reading-view ul > li > .list-bullet:after,
/* Bullet */
    height: 5px;
    width: 5px;
    border-radius: 50%;
/* LEVEL 2 */
.markdown-reading-view ul > li > ul > li > .list-bullet:after,
/* Dash */
    height: 1px;
    width: 7px;
    border-radius: 0%;
/* LEVEL 3 */
.markdown-reading-view ul > li > ul > li > ul > li > .list-bullet:after,
/* Hollow Bullet */
    height: 4px;
    width: 4px;
    border-radius: 50%;
    border-width: 1px;
/* LEVEL 4 */
.markdown-reading-view ul > li > ul > li > ul > li > ul > li > .list-bullet:after,
/* Solid Square */
    height: 5px;
    width: 5px;
    border-radius: 0%;
/* LEVEL 5 */
.markdown-reading-view ul > li > ul > li > ul > li > ul > li > ul > li > .list-bullet:after,
/* Dash */
    height: 1px;
    width: 7px;
    border-radius: 0%;
/* LEVEL 6 */
.markdown-reading-view ul > li > ul > li > ul > li > ul > li > ul > li > ul > li > .list-bullet:after,
/* Hollow Square */
    height: 4px;
    width: 4px;
    border-radius: 0%;
    border-width: 1px;
/* LEVEL 7 */
.markdown-reading-view ul > li > ul > li > ul > li > ul > li > ul > li > ul > li > ul > li > .list-bullet:after,
/* Small Bullet */
    height: 2px;
    width: 2px;
    border-radius: 50%;
/* bullet color */
:root { --bullet-new-color: rgb(89,89,223);}
(and @ObliviousMonkey - since you are looking for this too)
The first line of each block targets reading-view :butterfly:
Thank you very much!
When you get around to it, take a look at this:
@ZenMoto Thanks, it works great! And the new color is a nice touch :slightly_smiling_face:
@holroy This does work, but since I want different types of ordering depending on the level, it seems I cannot combine this with a multi numbered outline. e.g. I can have
  1. foo
    1.1. bar
    1.2. baz
or
  1. foo
    a. bar
    b. baz
but not
  1. foo
    1.a. bar
    1.b. baz
In the end I managed to get to a working solution for me with the following CSS snippet, where bullets show up correctly both in editing and preview, and where ordered and unordered markers are colored everywhere including in source:
/* Bullet color */
:root {
/* Change color for all types of markers
   in source, editing & preview           */
ol > li::marker,
ul > li::marker,
.cm-s-obsidian .cm-formatting-list {
 /* Unordered lists (bullets, dashes, circles...) */
/* first line targets reading view, second targets editing view */
/* LEVEL 1 */
/* Bullet */
    height: 5px;
    width: 5px;
    border-radius: 50%;
/* LEVEL 2 */
/* Dash */
    height: 1px;
    width: 7px;
    border-radius: 0%;
/* LEVEL 3 */
/* Hollow Bullet */
    height: 4px;
    width: 4px;
    border-radius: 50%;
    border-width: 1px;
/* LEVEL 4 */
/* Solid Square */
    height: 5px;
    width: 5px;
    border-radius: 0%;
/* LEVEL 5 */
/* Dash */
    height: 1px;
    width: 7px;
    border-radius: 0%;
/* LEVEL 6 */
/* Hollow Square */
    height: 4px;
    width: 4px;
    border-radius: 0%;
    border-width: 1px;
/* LEVEL 7 */
/* Small Bullet */
    height: 2px;
    width: 2px;
    border-radius: 50%;
 /*     Ordered lists (romans, ...)        */
/* LEVEL 1 */
.markdown-preview-section ol > li::marker {
    content: counter(list-item) ".\A0";
    /* color: var(--bullet-new-color) !important; */
/* LEVEL 2 */
.markdown-preview-section ol > li ol > li::marker {
    content: counter(list-item, lower-alpha) ".\A0"    ;
    /* color: var(--bullet-new-color) */
/* LEVEL 3 */
.markdown-preview-section ol > li ol > li ol > li::marker {
    content: counter(list-item, lower-roman) ".\A0";
/* LEVEL 4 */
.markdown-preview-section ol > li ol > li ol > li ol > li::marker {
    content: counter(list-item, upper-alpha) ".\A0";
/* LEVEL 5 */
.markdown-preview-section ol > li ol > li ol > li ol > li ol > li::marker {
    content: counter(list-item, upper-roman) ".\A0";
 Did not manage to target editing view for ordered lists,
 see failed attempts below
 https://forum.obsidian.md/t/how-to-customize-ordered-list-using-css/8242/2
/* LEVEL 1 */
/* .markdown-source-view.mod-cm6 .HyperMD-list-line-1 .cm-formatting.cm-formatting-list.cm-formatting-list-ol.cm-list-1: {
/* LEVEL 2 */
/* .markdown-source-view.mod-cm6 .HyperMD-list-line-2 .cm-formatting.cm-formatting-list.cm-formatting-list-ol.cm-list-2 {
span.cm-formatting-list-ol.cm-list-2::marker {
    content: counter(list-item, lower-alpha) ".\A0" !important;
/* LEVEL 3 */
/* .markdown-source-view.mod-cm6 .HyperMD-list-line-3 .cm-formatting. {
    content: counter(list-item, lower-roman) ".\A0"    ;
cm-formatting-list.cm-formatting-list-ol.cm-list-3 {
    content: counter(list-item, lower-roman) ".\A0" !important;
/* LEVEL 4 */
/* .markdown-source-view.mod-cm6 .HyperMD-list-line-4 .cm-formatting.cm-formatting-list.cm-formatting-list-ol.cm-list-4 {
Only thing missing is that the different numerical formats work only in reading mode, and not in editing mode. This is fine for me, since I’m used to have a split pane with source on the left and reading/preview on the right.
Thanks everyone!
