When I try to synchronize the Obsidian vault on Google Drive using the Free File Sync synchronization program I get the message: "Warning. The following folders do not exist yet (it refers to the folder I have destined for the vault). The folders are automatically created when needed. "
It basically can’t find my vault folders and therefore can’t sync them. Has anything like this happened to anyone? Thank you.
Google Drive doesn’t automatically download any files to your device. You may need to right-click the vault folder in Google Drive and set it to to be Make Available Offline, so that Free File Sync can see all the files:
