If you copy line 363 to 591 from .obsidian/themes/Primary/theme.css into your own snippets file (eg. add obsidian.css file to .obsidian/themes directory and enable in Settings > Appearance, as mentioned by @AlanG), it will add the Primary colours for both light and dark theme if you are using the Default Obsidian theme.
Necessary code pasted below.
++++++++++++Theme Colors++++++++++++++
Light Theme
.theme-light {
/*─────────Original Obsidian Variables──────────*/
--background-primary: var(--color-l-white);
--background-primary-alt: var(--color-l-gray-10);
--background-secondary: var(--color-l-gray-20);
--background-secondary-alt: var(--color-l-gray-20);
--background-modifier-border: var(--color-l-gray-40);
--background-modifier-form-field: var(--color-l-gray-30);
--background-modifier-form-field-highlighted: var(--color-l-gray-40);
--background-modifier-box-shadow: var(--color-l-shadow-100);
--background-modifier-success: var(--color-l-green-300);
--background-modifier-error: var(--color-l-red-300);
--background-modifier-error-hover: var(--color-l-red-500);
--background-modifier-cover: var(--color-l-shadow-cover);
--text-normal: var(--color-l-black);
--text-muted: var(--color-l-gray-60);
--text-faint: var(--color-l-gray-50);
--text-accent: var(--color-l-yellow-900);
--text-accent-hover:var(--color-l-yellow-500);
--text-error: var(--color-l-red);
--text-error-hover: var(--color-l-red-900);
--text-highlight-bg: var(--color-l-highlight-yellow);
--text-highlight-bg-active: var(--color-l-highlight-yellow);
--highlight-mix-blend-mode: darken;
--text-selection: var(--color-l-gray-40);
--text-on-accent: var(--color-l-gray-10);
--interactive-hover: var(--color-l-gray-10);
--interactive-accent: var(--color-l-gray-60);
--interactive-accent-rgb: 207, 182, 150;
--interactive-accent-hover: var(--color-l-gray-70);
--interactive-success: var(--color-l-green-500);
--scrollbar-bg: transparent;
--scrollbar-thumb-bg: var(--background-modifier-border);
--scrollbar-active-thumb-bg: var(--interactive-accent);
/*──────────The PRIMARY Color Palette for Light Theme──────────*/
--color-l-whiter: hsl(36, 36%, 96.9%);
--color-l-white: hsl(35, 36%, 95%);
--color-l-gray: var(--color-l-gray-50);
--color-l-gray-10: hsl(36, 37%, 92%);
--color-l-gray-20: hsl(35, 35%, 90%);
--color-l-gray-30: hsl(34, 36%, 88%);
--color-l-gray-40: hsl(36, 37%, 83%);
--color-l-gray-50: hsl(34, 37%, 70%);
--color-l-gray-60: hsl(34, 28%, 60%);
--color-l-gray-70: hsl(31, 23%, 50%);
--color-l-gray-80: hsl(34, 27%, 40%);
--color-l-gray-90: hsl(34, 30%, 37%);
--color-l-gray-100: hsl(35, 32%, 30%);
--color-l-black: hsl(31, 45%, 20%);
--color-l-blacker: hsl(32, 55%, 12%);
--color-l-shadow-10: rgba(168, 160, 148, 0.8);
--color-l-shadow-50: rgba(180, 172, 161, 0.3);
--color-l-shadow-100: rgba(75, 70, 64, 0.2);
--color-l-shadow-cover: rgba(177, 171, 164, 0.5);
--color-l-yellow: var(--color-l-yellow-500);
--color-l-yellow-300: hsl(43, 71%, 67%);
--color-l-yellow-500: hsl(43, 78%, 52%);
--color-l-yellow-700: hsl(43, 100%, 42%);
--color-l-yellow-900: hsl(43, 89%, 38%);
--color-l-red: var(--color-l-red-500);
--color-l-red-300: hsl(4, 54%, 61%);
--color-l-red-500: hsl(4, 72%, 55%);
--color-l-red-700: hsl(4, 56%, 48%);
--color-l-red-900: hsl(4, 66%, 30%);
--color-l-blue: var(--color-l-blue-500);
--color-l-blue-300: hsl(198, 39%, 56%);
--color-l-blue-500: hsl(205, 66%, 46%);
--color-l-blue-700: hsl(205, 63%, 39%);
--color-l-blue-900: hsl(205, 95%, 25%);
--color-l-orange: var(--color-l-orange-500);
--color-l-orange-300: hsl(26, 66%, 57%);
--color-l-orange-500: hsl(21, 82%, 55%);
--color-l-orange-700: hsl(18, 69%, 50%);
--color-l-orange-900: hsl(24, 96%, 35%);
--color-l-orange-a: hsl(27, 81%, 46%);
--color-l-green: var(--color-l-green-500);
--color-l-green-300: hsl(154, 58%, 65%);
--color-l-green-500: hsl(154, 47%, 49%);
--color-l-green-700: hsl(155, 52%, 38%);
--color-l-green-900: hsl(165, 63%, 29%);
--color-l-violet: var(--color-l-violet-500);
--color-l-violet-300: hsl(270, 50%, 74%);
--color-l-violet-500: hsl(266, 31%, 57%);
--color-l-violet-700: hsl(267, 37%, 43%);
--color-l-violet-900: hsl(266, 70%, 30%);
/*~ Highlights */
--ui-color-highlight-text: var(--color-l-black);
--ui-color-highlight-bg: hsl(43, 85%, 79%);
--color-highlight-yellow: rgba(255, 187, 0, 0.2);
--color-highlight-red: rgba(240, 79, 106, 0.2);
--color-highlight-blue: rgba(40, 178, 194, 0.2);
--color-highlight-orange: rgba(255, 115, 0, 0.2);
--color-highlight-green: rgba(153, 189, 36, 0.2);
--color-highlight-violet: rgba(113, 122, 255, 0.2);
/*~ Graph View */
--graph-color-node-resolved: var(--color-l-blue-500);
--graph-color-node-unresolved: var(--color-l-yellow-500);
--graph-color-node-unresolved-opacity: 1;
--graph-color-node-tag: var(--color-l-red-500);
--graph-color-node-attachment: var(--color-l-green-300);
--graph-color-node-focused: var(--color-l-gray-80);
--graph-color-node-border-hover: var(--color-l-gray-50);
--graph-color-node-arrow: var(--color-l-gray-60);
--graph-color-node-line: var(--color-l-gray-40);
--graph-color-node-line-hover: var(--color-l-gray-50);
--graph-color-node-text: var(--color-l-black);
Dark Theme
.theme-dark {
--background-primary: var(--color-d-gray-70);
--background-primary-alt: var(--color-d-gray-90);
--background-secondary: var(--color-d-black);
--background-secondary-alt: var(--color-d-black);
--background-modifier-border: var(--color-d-gray-50);
--background-modifier-form-field: var(--color-d-blacker);
--background-modifier-form-field-highlighted: var(--color-d-black);
--background-modifier-box-shadow: var(--color-d-shadow-100);
--background-modifier-success: var(--color-d-green-300);
--background-modifier-error: var(--color-d-red-500);
--background-modifier-error-hover: var(--color-d-red-700);
--background-modifier-cover: var(--color-d-shadow-cover);
--text-normal: var(--color-d-white);
--text-muted: var(--color-d-gray-20);
--text-faint: var(--color-d-gray-30);
--text-accent: var(--color-d-yellow-500);
--text-accent-hover:var(--color-d-yellow-300) ;
--text-error: var(--color-d-red-500);
--text-error-hover: var(--color-d-red-300);
--text-highlight-bg: var(--color-d-highlight-yellow);
--text-highlight-bg-active: var(--color-d-highlight-yellow);
--highlight-mix-blend-mode: lighten;
--text-selection: var(--color-d-gray-50);
--text-on-accent: var(--color-d-white);
--interactive-hover: var(--color-d-gray-60);
--interactive-accent: var(--color-d-gray-40);
--interactive-accent-rgb: 92, 78, 61;
--interactive-accent-hover: var(--color-d-gray-50);
--interactive-success: var(--color-d-green-700);
/*──────────The PRIMARY Color Palette for Dark Theme──────────*/
--color-d-whiter: hsl(33, 66%, 90%);
--color-d-white: hsl(34, 50%, 80%);
--color-d-gray: var(--color-d-gray-50);
--color-d-gray-10: hsl(34, 18%, 62%);
--color-d-gray-20: hsl(35, 27%, 55%);
--color-d-gray-30: hsl(34, 24%, 30%);
--color-d-gray-40: hsl(33, 22%, 30%);
--color-d-gray-50: hsl(33, 20%, 20%);
--color-d-gray-60: hsl(30, 19%, 17%);
--color-d-gray-70: hsl(27, 14%, 15%);
--color-d-gray-80: hsl(32, 19%, 13%);
--color-d-gray-90: hsl(30, 15%, 13%);
--color-d-gray-100: hsl(30, 20%, 8%);
--color-d-black: hsl(27, 15%, 12%);
--color-d-blacker: hsl(26, 16%, 9%);
--color-d-shadow-10: rgba(29, 21, 13, 0.45);
--color-d-shadow-50: rgba(29, 26, 22, 0.75);
--color-d-shadow-100: rgba(19, 16, 13, 0.95);
--color-d-shadow-cover: rgba(37, 34, 29, 0.74);
--color-d-yellow: var(--color-d-yellow-500);
--color-d-yellow-300: hsl(46, 91%, 69%);
--color-d-yellow-500: hsl(50, 100%, 46%);
--color-d-yellow-700: hsl(43, 100%, 42%);
--color-d-yellow-900: hsl(39, 92%, 33%);
--color-d-yellow-a: hsl(43, 75%, 52%);
--color-d-red: var(--color-d-red-500);
--color-d-red-300: hsl(4, 100%, 68%);
--color-d-red-500: hsl(4, 65%, 60%);
--color-d-red-700: hsl(4, 90%, 61%);
--color-d-red-900: hsl(4, 77%, 38%);
--color-d-red-a: hsl(4, 61%, 53%);
--color-d-blue: var(--color-d-blue-500);
--color-d-blue-300: hsl(198, 39%, 56%);
--color-d-blue-500: hsl(198, 62%, 57%);
--color-d-blue-700: hsl(198, 57%, 55%);
--color-d-blue-900: hsl(198, 75%, 35%);
--color-d-blue-a: hsl(197, 58%, 48%);
--color-d-orange: var(--color-d-orange-500);
--color-d-orange-300: hsl(22, 92%, 64%);
--color-d-orange-500: hsl(22, 92%, 57%);
--color-d-orange-700: hsl(21, 88%, 51%);
--color-d-orange-900: hsl(20, 80%, 41%);
--color-d-orange-a: hsl(27, 77%, 51%);
--color-d-green: var(--color-d-green-500);
--color-d-green-300: hsl(150, 66%, 53%);
--color-d-green-500: hsl(154, 52%, 46%);
--color-d-green-700: hsl(154, 61%, 39%);
--color-d-green-900: hsl(155, 81%, 24%);
--color-d-green-a: hsl(96, 50%, 49%);
--color-d-violet: var(--color-d-violet-500);
--color-d-violet-300: hsl(256, 63%, 74%);
--color-d-violet-500: hsl(263, 60%, 67%);
--color-d-violet-700: hsl(256, 52%, 57%);
--color-d-violet-900: hsl(256, 44%, 50%);
--color-d-violet-a: hsl(246, 53%, 67%);
/*~ Highlights */
--ui-color-highlight-text: var(--color-d-black);
--ui-color-highlight-bg: hsl(43, 61%, 56%);
/*~ Graph View */
--graph-color-node-resolved: var(--color-d-blue-900);
--graph-color-node-unresolved: var(--color-d-yellow-700);
--graph-color-node-tag: var(--color-d-red-500);
--graph-color-node-attachment: var(--color-d-green-500);
--graph-color-node-focused: var(--color-d-white);
--graph-color-node-border-hover: var(--color-d-gray-10);
--graph-color-node-arrow: var(--color-d-gray-40);
--graph-color-node-line: var(--color-d-gray-50);
--graph-color-node-line-hover: var(--color-d-gray-40);
--graph-color-node-text: var(--color-d-gray-10);
