Disclaimer
Is this project open source? Yes/No
Is this project completely free? Yes/No
Is this project made with AI beyond the author’s ability to comprehend how it works? Yes/No
Workflows
- When using OCR technology like
Window Powertoolscopying from screen. - When copying a YouTube transcript with line-breaks.
- When copying from research papers, books, or other PDF files which have disjoint line breaks.
- (etc.)
Showcase
A custom script which tries to “calculate” line breaks and groups text into sentences.
- Paste the code snippet below into the
User Pluginsplugin. - TIP: Depending on your purposes, you can mess with the constants
SENSITIVITY,SHORTER_THAN_AVG_RATIO, andAVG_LENGTH_PERCENT. These numbers work well for 60+ character lines.
/* Identifies "true line breaks" for resources which break every row */
const processText = (text) => {
let normalized = text.replace(/\r\n/g, '\n').replace(/\r/g, '\n');
const lines = normalized.split('\n').map(line => line.replace(/[ \t]+$/, ''));
const outputLines = [];
const lengthHistory = [];
const HISTORY_SIZE = 6;
const SENSITIVITY = 10;
const SHORTER_THAN_AVG_RATIO = 1.1;
const AVG_LENGTH_PERCENT = 0.66;
// PART 1: Detect punctuation (only new bullet points at sentence-end)
const PUNCTUATION_REGEX = /([.?!:'"\u201d]|\.{3})$/;
const calculateAverageLength = (history) => {
if (history.length === 0) return 0;
// PART 2.1: < "Average Length" Threshold = Irrelevant to "average"
const maxLength = Math.max(...history); // Find (historical) max length
const threshold = maxLength * AVG_LENGTH_PERCENT + SENSITIVITY; // Calc. threshold
const relevantLengths = history.filter(len => len >= threshold); // Filter history
if (relevantLengths.length === 0) {
const total = history.reduce((sum, len) => sum + len, 0);
return total / history.length;
// PART 2.2: Re-calculates new average w/ only relevant (longer) lines
const total = relevantLengths.reduce((sum, len) => sum + len, 0);
return total / relevantLengths.length;
for (let i = 0; i < lines.length; i++) {
const currentLine = lines[i];
const currentLength = currentLine.length;
// PART 3.1: Identifies all "line vs. paragraph breaks"
if (currentLength === 0) {
if (outputLines.slice(-1)[0] !== '\n') {
outputLines.push('\n');
continue;
// PART 3.2: "Lookahead" -> Add 1/2 of next line's word
let effectiveCurrentLength = currentLength;
if (i < lines.length - 1) {
const nextLine = lines[i + 1];
if (nextLine.length > 0) {
const firstWordMatch = nextLine.match(/^\S+/); // First word
if (firstWordMatch) {
const firstWordLength = firstWordMatch[0].length;
effectiveCurrentLength += Math.floor(firstWordLength / 2); // Length += 1/2 next
// PART 3.3: If ends with punctuation & is ANOMOLY in short-length, add line break
const endsWithPunctuation = PUNCTUATION_REGEX.test(currentLine);
let shouldAddBreak = false;
if (endsWithPunctuation) {
const averageLength = calculateAverageLength(lengthHistory);
let isAnomalouslyShort = false;
if (lengthHistory.length >= 1) { // Assumes 1st 2x lines aren't new paragraph
if (effectiveCurrentLength < averageLength * SHORTER_THAN_AVG_RATIO) {
isAnomalouslyShort = true;
if (isAnomalouslyShort || lengthHistory.length < 2) {
shouldAddBreak = true;
// PART 3.4: Update line length history
if (currentLine.length > 0) {
lengthHistory.push(currentLength);
if (lengthHistory.length > HISTORY_SIZE) {
lengthHistory.shift();
// PART 3.5: Splits if ANOMOLY short-length
outputLines.push(currentLine); // Add current line to output
// Add separator unless it's the last line
if (shouldAddBreak) { outputLines.push('\n'); }
else { outputLines.push(' '); }
// PART 4: Final cleanup: remove potential double spaces and trim
let finalOutput = outputLines.join('').replace(/ {2,}/g, ' ');
return finalOutput.trim();
plugin.addCommand({
name: 'Paste and Normalize Paragraphs',
callback: async () => {
const activeFile = app.workspace.getActiveFile();
const activeView = app.workspace.activeLeaf.view;
if (!activeView || !activeView.editor) {
console.warn("No active editor view available.");
return;
// PART 1: Normalize paragraphs
const editor = activeView.editor;
const currPos = editor.getCursor();
const clipboard = await navigator.clipboard.readText();
if (!clipboard) {
console.warn("Clipboard is empty. Cannot paste.");
return;
const processedText = processText(clipboard);
editor.replaceRange(processedText, currPos);
const endPos = editor.offsetToPos(editor.posToOffset(currPos) + processedText.length);
editor.setSelection(currPos, endPos);
