[Plugins Required] Copy and Clean Video Transcripts
Disclaimer
Is this project made with AI beyond the author’s ability to comprehend how it works? No
Ever wanted to copy a video transcript from YouTube into your vault so that you could archive a specific section, quote, or maybe just the entire thing because the creator’s entire video was so informative?
TIP: If you’re a Firefox user, extensions exist (I can’t validate their safety at all; this is not an advertisement) so you don’t have to drag your cursor from start to end; I use YouTube Transcript Copier by Dislike Lever.
Showcase
  1. STEP 1: Go to my other post and follow the instructions to fix the disjoint paste from YouTube transcripts: https://forum.obsidian.md/t/plugins-required-fixing-disjoint-line-breaks-in-pdfs-when-copying-text/118042
  2. STEP 2: Install the QuickAdd plugin (and maybe the Editing Toolbar plugin if you have a lot of scripts/don’t remember what they all are).
  3. STEP 3: Copy the script at the bottom of this post. Add it to User Plugins.
  4. STEP 4: Create a QuickAdd Macro to User Plugins: Paste & Normalize, then wait some milliseconds (I set it to 1,000, though that’s overkill), and then to run the new script User Plugins: Clean Video Transcript. Call it whatever, though I named it Paste Video Transcript for a generic name.
/* Transcripts: Removes timestamps/filler words/repetition, adds capitalization */
plugin.addCommand({
    name: 'Clean Video Transcript',
    callback: async () => {
        const activeView = app.workspace.activeLeaf.view;
        const editor = activeView.editor;
        let corrected = await editor.getSelection();
        if (!corrected) {
            window.alert("No text in selection");
            return;
        // PART 1: Remove timestamps
        corrected = corrected.replace(/(\n- )*([\s?!.,;…])*(\s*?)(\([0-9]+(:[0-9]+)+\))(\s*)/g, "$1$2");
        corrected = corrected.replace(/(\n- )*([\s?!.,;…])*(\s*?)([0-9]+(:[0-9]+)+((,|\s)*[0-9]+ (minute|second|hour)(s*))*)(\s*)/g, "$1$2");
        // PART 2: Remove "uh" and [music]
        corrected = corrected.replace(/(^|[^A-Za-z0-9])((U|u)h|(U|u)m|(Y|y)ou know)([,]*)(\s*)/g, "$1");
        corrected = corrected.replace(/(\[(M|m)usic\])(\s*)/g, "");
        corrected = corrected.replace(/(\[\s*__\s*\])/g, "\\[expletive\\]");
        // PART 3: Capitalize properly
        let re = /([?!.…]\s|\n- )[a-z]/g;
        corrected = corrected.replace(re, function(x){ return x.toUpperCase(); });
        // PART 4: Remove repetition (2x words)
        corrected = corrected.split(" ");
        let corrected2 = [];
        while(corrected.length > 0) {
            let c = corrected.shift();
            if(corrected2.length == 0 || !(c.toUpperCase() === corrected2[corrected2.length - 1].toUpperCase())) { corrected2.push(c); }
        corrected2 = corrected2.join(" ")
        editor.replaceSelection(corrected2);
