Plug-in or CSS code to allow seamless block referencing?
I have been unsuccessful in locating a plug-in or CSS code snippet that will allow me to integrate block references without disrupting the aesthetics or flow of the document. Can someone point me towards a solution (copy and paste is not an option for my purposes)?
Hopefully this screenshot will illustrate what I am searching for:
Do you mean inline embed? I think there’s no plugin or CSS for it currently. Yet, it’s already requested :
But, there’s a CSS hack for workaround (but it’s not similar with your example, but you might want to check it)
Thanks for the help! I have tried out the CSS hack and, like you mentioned, it doesn’t suffice. I’ll head over to the feature request and add my support.
Thanks, again.
