This is a pink obsidian theme for stimulating happiness. It is designed to create the most compassionate and sweetest environment for reading, thinking and writing.
This theme started out as a set of snippets on top of the Blue Topaz as soon as I realized WhyI’s Blue Topaz does all the features I was ever trying to do in my DIY snippets and got the job done in a much nicer way. I have worked to collect colours from photos, websites as inspirations to make it more aesthetically appealing. I hope Pink Topaz calms and reassures your emotional energies the way it did to me and my friends.
If you like a more inspiring and neutral theme, check out my Golden Topaz. ![]()
Download
You can find this theme in the Obsidian’s community themes browser under Settings > Appearance > Themes.
Change log
- 2021-06-01
- Improved code block background colour in dark mode in edit mode.
- Improved colour scheme for dataview and code block.
- 2021-05-30
- Fixed colours for mermaid chart
- 2021-05-25
- Improved all 13 core coding syntax colours
- Improved some tag colours
- 2021-05-24
- Added 20 major coding languages syntax highlighting colours.
- 2021-05-23
- Improved graph hover effects.
- Improved outline hover effects
- 2021-05-20
- Added even more sublime graph view colours.
- Now pictures, tables and videos will be in the middle of the page, no longer on the left side.
- changed colours for focus mode when typing in edit mode
- text alignment and be adjusted by: Syntax: start | end | left | right | center | justify | match-parent
- 2021-05-19
- changed colours for indent-lines for better reading experience.
- 2021-05-18
- added better colours for day planner timeline view when one day
has more than 10 tasks.
Features & Screenshots
Aesthetic matters! This is the first all-pink obsidian theme
Colours support all charts and tables and blocks and tags etc from core and plug-ins. Interactive hover for outlines and charts etc all have hand-picked colours
Wherever you edit, a pink field will help you focus(the line above “- asga” is highlighted in light pink)
Quotes and embeddings look nice in pink
Hand picked colours for code and syntax
Dark mode has all the features, just sexier
PS: Is it just me or when using this theme long enough, You would become everybody’s crush. Hope you enjoy it ![]()
That is the nickname of my pet.
