Chromium’s Skia/PDF m113, the thing that gives “Save to PDF” in the print page dialog of the browser, exports HTML to PDF correctly, with functioning internal links.
In Obsidian v1.3.3 accessing process.versions in the Dev Tools (Ctrl+Shift+I on Windows) shows Chrome at version 112.0.5615.183 and Electron 24.3.1 (latest stable)
So I guess it’s not a question of the Obsidian team updating Electron.
This bug probably involves some post-processing of the note’s generated preview markup which must have some custom solution to internal links. That has to be turned back into real HTML anchor links, so that printToPDF can do the PDF conversion correctly.
Is this hard to do, would it introduce breaking changes or something?
I agree! It is one of my highly requested features for Obsidian.
But just a thought:
Perhaps it is not since it kind of reduces the need for the users to pay for the subscription that allows them to collaborate with each other.
If you can simply print the .pdf and the .pdf works almost exactly like the note and then you use that file for documentation for your co-workers, perhaps you won’t need to pay for that subscription.
+1 for a this feature request, I have a plethora of reasons to export .md docs to pdf and it’s a bit disappointing that none of my tables of content function when I do so. Any one have a work-around for now?
thx, for any help, or the feature implementation, if it’s possible…
Great big +1 from me! I’ve just wasted a day trying to write a Python script to fix internal links in Obsidian exported PDF files. PDF is such a cursed format
It’s a strange problem. Footnotes in the exported PDF work - along with the link by a footnote to take you back to the main text where the footnote marker is - but # links made by hand don’t. I wonder what’s happening during the export process that means footnote links work, but # links don’t?
would love to see this implemented in Obsidian, very useful feature, I’m surprised it’s been years since this was requested and not yet implemented. I totally understand the complexities of a roadmap and the prioritization of other requests by the developers.
I would love to see this as well but I fear it’s is not easy to implement, since obsidian seems to use the print function of the chromium browser it is built on and redirects the output into a pdf.
Currently pandoc with crossref seems the only option to generate a pdf with working links. Unfortunately pandoc doesn’t support obsidian wikilinks. But there is a plugin (I think it is called link converter) to convert obsidian links into standard markdown links that can be handled by pandoc.
There are two plugins as far as I know that integrate pandoc into obsidian. One of these is obsidian-enhancing-export. But its not easy to setup a working pandoc environment. In particular you need also e latex environment since pandoc cannot translate markdown directly to pdf but first convert it to latex which is then converted to pdf using pdflatex or xelatex.
I’ve been thinking about this, and I think I’ve worked out a possible solution, based on the fact that external (http://) links work.
Just before a PDF is exported, rewrite all in-document links to dummy external links, e.g a link to [[#Some heading]] gets rewritten to [Some heading](http://dummy.url/#Some%20heading)
I think it’d be possible to write an Obsidian plugin to do this, either by hooking up a notification to when PDFs get exported, or triggering PDF export from the plugin itself.
Based on my limited understanding of the PDF format, it might be quite hard to do 3), since I believe PDF internal links are based on actual locations in the document (e.g ‘a rectangle halfway down the page on page 23’) rather than named headers (eg ‘#Some heading’). Should be doable though, even if it’s just by searching through the document looking for the location of ‘Some heading’ in the correct style or something.
Anyway. My time for actual coding is very limited right now (I’m trying to finish a big writing project), but I might have a crack at it when that project is done.
Woohoo, got a proof of concept plugin working! It’s nowhere near ready to release yet, but all the parts that implement the solution I proposed are in place, and it kinda works mostly!
Posting here in case anyone else who can code Obsidian plugins would like to pick it up and refine it a bit further. I’m not going to have any time to work on it for a couple of weeks.
For clarity: this is not a plugin ready for everyday use. It’s code for developers only which proves that it’s possible
The Footnote when exported to pdf work amazingly just like what we need, sadly i cant choose the location for the foot note otherwise this would be solved
