Thank you! I’ll try to turn off other plugins and CSS theme. I hadn’t thought of that.
One problem I have with this mode is that Crtl + F ing. It doesn’t open the folded bullets. Altho it maybe more of a folding problem in general, I don’t know.
Also I would appreciate it if compatibility with RTL languages get fixed.
Otherwise it is a awesome plugin, thank you for your efforts
If you see bugs or would like to see some feature, please go to GitHub page and fill the issue there, the author of the plugin doesn’t often visit the forum
I’d love if Obsidian integrated the community Outliner plug-in into the product directly (so it’s fully supported).
Looks as if the comunity plug-in would need complete rewriting to work with Codemirror 6.
I don’t know if some features would be added easily (in which case possibility of being added to core might exist). Otherwise quite a wait maybe.
Love your plugin. It would be nice if we can add or make headlines H2, H3, H4 within the outliner without the need to separate the outline then write the headline then start a new outline. As this takes out (or limits) the flexibility of moving section up/down. Keep it going.
Yes, pls consider including headers as part of the outlining hierarchy.
Working with headers: indent/outdent, move up/down
Giving my vote to this idea! Obsidian is awesome and deserves a proper outlining experience <3
