The inline displaying of titles since release 0.16.0 is lovely! It makes titles a more integral part of every note.
However for historical reasons people have been using workarounds (sometimes even plugins) to achieve this, which now results in duplicated titles (note title + identical first heading) for many existing vaults.
In the Settings → Editor → Display category change the Show inline title setting from a toggle to a 3-way menu:
always
unless identical to topmost heading
never
The middle setting could provide a clean transitional period, until old notes are reworked across the vault.
Manually go through the vault and delete redundant first headings, possibly also raising all heading levels by 1. Or just learn to live with duplicate titles.
I know there’s an in-built solution for this, but if you or anyone else are still looking for an alternative workaround, I’ve worked out that you can delete the redundant headers and raise the heading levels by using regex in VSCode.
Open vault in VSCode (manually or through this plugin).
Find and replace in all files Ctrl+Shift+H.
To delete title header, use this regex search string: ^#\s.*$\n. Leave the replace field blank, and click replace.
Note: This will delete all first-level headings. This is fine for me because I only use first-level headings for titles, but if you use them for other text, they will be deleted too. You’ll have to figure out another search string specific to your title header (e.g. if you use metadata then you can add ---).
To raise all heading levels, find ^## and replace with #.
I prefer this method because I’m against redundancy. Also, since I’m only using {{title}} instead of plugins, it’s far more convenient to use Obsidian’s feature, now that it’s (or will be, since I’m not an insider) available.
