These URLs are from the copy URL from a note in my vault and when entered into Safari they do not open the specific vault, just opens the current vault.
I have search Obsidian help blocks opening own vault
Creating or opening a new vault doesn’t work
I am looking to open specific vault automatically with shortcuts, stuck on opening vaults automatically. I am using Obsidian version v1.0.3 on IPad.
It sounds like you solved your problem, but FYI: Obsidian URLs unfortunately don’t work right on mobile if Obsidian isn’t already started (for example, when you’ve switched away from Obsidian and used several apps, causing the system to push it out of memory). Here’s the bug report about it:
