Open settings shortcut (cmd+,) does not work
press cmd+,
Settings open
Settings do not open
  • Obsidian Version 1.12.7 (Installer 1.8.10)
  • MacOS 26.4
    But it has been the case since a long time (at least 6 months)
No themes nor extensions installed
For me it works.
Is the shortcut actually assigned? (Check Settings>Hotkeys>Open settings)
Does it work if you assign a different shortcut?
Yes, it is assigned to the default one.
It works if I assign it to an other one (tried with cmd+=).
Don’t know if useful, but I’m on a AZERTY (FR) keyboard.
Also, cmd+, works on all my other apps.
Probably this
It’s likely this, indeed.
Though it seems that I still can’t edit t “Open settings” to the the cmd+,
Nothing happens when clicking this and pressing the shortcut.
