I updated for new obsidian and not working i tryed many things like removing caching and disable gpu but still not working and not opening
Please use the template when posting in Bugs. Moved to Help.
Which Linux installer did you use? What other information can you include?
i used kali linux which based on debian and i try all installer same problme
Gotcha, and what do you mean by “not working”? You said “not opening”, but then how do you disable GPU? Is it the app or the vault that won’t open?
Maybe try this, if it seems like the same problem? This user had to delete the .config folder. Obsidian opens blank
