Obsidian forgets all about my custom obsidian preferences when my vault is unmounted
I have a vault on an external drive.
For reasons having to do with syncronization, I use an alternate name “.macos” instead of “.obsidian” for my obsidian prefs folder.
If I launch obsidian before the external drive has a chance to mount (as happens automatically with MacOS sometimes, annoyingly), then it forgets this folder and I have to go back and type it inot the prefs again.
Every time I boot, I go through this ritual.
The problem seems to be that if Obsidian cannot find a vault, it just deletes all record that it ever opened it.
Can Obsidian please just remember the last 5 vaults I used? If they are cluttering up my sidebar, make them removable!
Thanks
  • Yes I have a lot of plugins, but this problem happens before they load.
Obsidian version: v1.6.7
Installer version: v1.4.13
Operating system: Darwin Kernel Version 23.6.0: Fri Jul 5 17:56:41 PDT 2024; root:xnu-10063.141.1~2/RELEASE_ARM64_T6000 23.6.0
Catalyst license: insider
Insider build toggle: on
Base theme: light
Community theme: Minimal v7.7.0
Snippets enabled: 2
Plugins installed: 98
Plugins enabled: 87
1: Advanced URI v1.40.1
2: Dataview v0.5.67
3: Emoji Toolbar v0.4.1
4: Editor Syntax Highlight v0.1.3
5: Dynamic Highlights v0.3.1
6: Dangling links v0.3.0
7: Daily Activity v0.5.0
8: Buttons v0.5.1
9: Code Block Enhancer v1.0.5
10: Contextual Typography v2.2.5
11: Commander v0.5.1
12: Copy as HTML v1.1.3
13: Copy Block Link v1.0.4
14: BRAT v1.0.1
15: Link Converter v0.1.6
16: Enhancing Export v1.10.6
17: Markmind v2.0.0
18: Pandoc Plugin v0.4.1
19: Paste URL into selection v1.7.0
20: Periodic Notes v1.0.0-beta.3
21: Persistent Graph v0.1.5
22: Pinboard Sync v1.0.2
23: QuickAdd v1.9.1
24: Omnisearch v1.23.1
25: Janitor v1.0.7
26: Regex Find/Replace v1.2.0
27: Scales and Chords v1.0.1
28: Shell commands v0.22.0
29: Show Current File Path v0.5.2
30: Snippet Commands v0.0.2
31: Sort & Permute lines v0.7.0
32: Templater v2.3.3
33: TimeStamper v1.3.0
34: Tracker v1.14.0
35: Show Whitespace v0.3.1
36: Tasks v7.5.0
37: Waypoint v2.1.0
38: Workspaces Plus v0.3.3
39: HTML Tags Autocomplete v0.0.7
40: Recent Files v1.4.1
41: Charts v3.9.0
42: Note Refactor v1.8.2
43: Natural Language Dates v0.6.2
44: Minimal Theme Settings v8.0.2
45: Mind Map v1.1.0
46: Metadata Extractor v1.1.0
47: Keyboard Analyzer v0.1.3
48: Highlightr v1.2.2
49: Frontmatter Tag Suggest v0.4.1
50: Format Hotkeys v0.1.7
51: Find orphaned files and broken links v1.10.0
52: File Info Panel v1.3
53: Projects v1.17.3
54: ibook v2.0.12
55: Media DB v0.7.1
56: Sortable v0.3.1
57: Hot Reload v0.1.10
58: Task Collector (TC) v1.0.17
59: Chronology v1.1.11
60: Media Extended v3.2.4
61: Timestamp Notes v1.0.8
62: Settings Search v1.3.10
63: Linter v1.24.0
64: Archiver v0.26.1
65: Quiet Outline v0.3.35
66: Typewriter Scroll v0.2.2
67: Dictionary v2.22.0
68: Local Images Plus v0.15.9
69: Packrat v1.1.2
70: DB Folder v3.5.1
71: Calendar v1.5.10
72: Solve v1.0.2
73: Quick Tagger v2.2.3
74: Admonition v10.3.2
75: Better Word Count v0.10.1
76: Vault Statistics v0.1.3
77: Outliner v4.8.1
78: Collapse All v2.1.0
79: Fast Image Cleaner v0.8.3
80: Image Converter v1.1.7
81: Multi Properties v1.1.1
82: Style Settings v1.0.8
83: _Wealthychef’s Image Resizer v1.0.0
84: Plugin Reloader v0.0.3
85: _Wealthychef’s Amazing Tag Deleter v1.0.0
86: _Wealthychef Tag Wrangler v0.6.1
87: Remember File State v1.1.2
Duplicate of
