Hi All,
As a newbie to the Forum so I hope I ticked the correct boxes.
Since very recent I started to use community add-ons, in this case ‘Dataview’, and i am not sure if I made a mistake or if something got broken due to the most recent Obsidian for Windows update. So I am wondering if you experience issues since Obsidian 1.4.5 with Dataview 0.5.56, or if it’s just me messing things up.
I was very pleased in achieving some cool backlink-tables and tasklists from notes that link to my Dossier note. The code is below. It worked fine yesterday, but I am still in the “development mode”, so I might have broken it.
FTR, if I look in the Backlinks sidebar, there are notes linked. I link them in the “default” way by encapsulating them into two square brackets like this [[Note]].
The dataviews
This one should show the not completed tasks from notes that link to the “overview” note, but doesn’t show a thing.
```dataview
TASK
WHERE contains(this.file.inlinks, file.link)
WHERE !completed
This is meant to show notes linked to the “overview” note, but again doesn’t show a thing.
```dataview
table without id
link(file.link, title) as "Note name",
file.mtime as "Modified"
where contains(this.file.inlinks, file.link) AND file.name != this.file.name
sort "Note name" desc
If I remove AND file.name != this.file.name
, it only shows the “overview” note that holds the dataview code. I also tried a this simple (almost foolproof) code that I found on the forum. That also only shows the note that holds the dataview code.
```dataview
TABLE without id file.inlinks
WHERE file.name = this.file.name
Concrete question
So, since I think my code is correct, I think it’s an issue with Obsidian 1.4.5 in combination with Dataview 0.5.56. But before creating an issue on Github, I am curious if anyone else experiences the same issues or if it’s me failing in my code.
