I noticed that several of my notes are displaying as reds lines. This vault his synced with vault.
Can’t figure what is causing this. Any thoughts on how to address this would be helpful.
Looks like
A quick scan of that thread suggests trying the File Recovery core plugin on those notes.
If File Recovery doesn’t work, can you please paste the results of the command “Show debug info”?
Did your computer crash / shut down unexpectedly?
Thank you.
I’ll give a file recovery a try. I’ll send the you logs if it doesn’t work.
