Nextcloud and Obsidian on Mobile
Hey there!
Today I wanted to show you my syncing-setup with Nextcloud and Obsidian, which works surprisingly well.
Before Nextcloud I was completely dependend on Onedrive (Windows User since 9 years old). But after I got my own server for fun, I educated myself more and more about privacy, and came to the shocking conclusion, that I don’t want microsoft to have controll over my files.
Nextcloud was fairly easy to install. At first I wasn’t grasping the whole power I now got under my hands.
But after I descided to move everything to my server, I started experimenting. There are quite some apps for mobile to use with your nextcloud-server. One of them is called “Nextcloud Notes”. I installed it, and you can point it to a folder on your server, where it will then store the notes as markdown files.
So I pointed it to the “inbox” Folder of my Vault - and voilà, I am now able to jot down a note in seconds on mobile, and have it instantly synced with my inbox-folder. The only downside to this is, that I don’t have all the features of Obsidian, like linking, etc. But I use this system now for over 6 Months, and I don’t even need those features, when it has to be quick.
When I get back to my Vault on my PC then, I sort everything (weekly sometimes) and link everything. The cool thing is, also notes I create in my vault in this folder get linked to the app!
Also: when you cteate categories in the App, they are just folders in the inbox-folder!
Find some screenshots attached below. I hope someone can use this.
cheers!
This is my vault in Obsidian:
And this is the Notes App:
And here is the Server:
Hi :wave:
Why you don’t use the Obsidian mobile instead of the Nextcloud Notes mobile ?
It makes sense, no ? :thinking:
Well, i have almost 3000 Notes in my vault, and Obsidian on mobile is getting really slow. I am just experimenting with syncing just one folder with obsidian sync, but nextcloud notes is lightning fast…
Really cool !!! Don’t hesitate to share your experience on the Nextcloud Forum!! :smiley:
Do you meet issues when you synchronize between your Obsidian and Nextcloud? Are you getting well your files / vault on your machines synchronized ?
Hey there, thanks! I will!
As of now this method is the best for my usecase, and I don’t encounter any problems. In fact it runs so well, and the mobile app is so fast, that I prefer this method over Obsidian Sync. Which is a bummer for the Obsidian Team, but what you gotta do…
As you have stated, Obsidian and Nextcloud Notes is a very good combination, especially if you work simulataneously with stationary computers and mobile devices. I have been using it for more than a year with a hosted Nextcloud instance.
I would like to make two remarks:
  • For Obsidian and Nextcloud Notes to work together, it was necessary to set the default extension for notes files to .md in the Nextcloud configuration.
  • Unfortunately, Obsidian extensions such as Callouts or Canvas do not work with Nextcloud Notes. But you can’t have everything.
How do you sync NC notes with Obsidian vault on your computer? I’m testing NC running on a digitalocean droplet(aka VPS) now . SInce it’s hosted on the Internet, it doesn’t have access to files on my computer.
How do you get the NC server files to sync with your computer?
Hello, thanks for the awesome idea!
I also use this and as long as the folder structure is just one deep, it works flawless!
A bit off topic, but which plugin are you using for the folder coloring with the colored dots on the side?
