Next/Previous Daily Note hotkeys does not work with subfolders
  1. Create a new vault
  2. Enable daily notes plugin
  3. Assign ‘Alt-d’ to 'Daily notes: Open today’s daily note
  4. Assign ‘Alt-n’ to 'Daily notes: Open next daily note
  5. Assign ‘Alt-p’ to 'Daily notes: Open previous daily note
  6. Set 'YYYY/M/YYYY-MM-DD as daily note date format
  7. Create and set /journal as folder for daily notes
  8. Hit ‘Alt-d’ to go to todays daily note. Edit it
  9. Create similar notes for yesterday and tomorrow in the same folder
‘Alt-p’ and ‘Alt-n’ would result in going to previous and next daily notes, respectively
‘Alt-d’ navigates to the correct note. Nothing happens when pressing ‘Alt-p’ and ‘Alt-n’.
I am using Obsidian 12.16 on Ubuntu Linux
This did work earlier, but stopped working a few minor releases ago.
No messages appear in the developer console.
We do not support this. Please, open a feature request.
Ok. See feature request
