Next and previous daily note commands go missing
In a new sandbox vault, specify the following format without quotes in the “Daily notes” → “Date format” setting: “YYYY/YYYY-MM-DD”. Any format with a folder prefix like this will do.
The ‘Daily notes: Open next daily note’ and ‘Daily notes: Open previous daily note’ commands should show up in the Command Palate, and hotkeys assigned to these commands should work.
These ‘next’ and ‘previous’ commands disappear from the UI when the format has a folder prefix and do not work if hotkeys are assigned to them.
The “Open today’s daily note” command does work and creates the folder specified by the format as needed.
Obsidian version: v1.3.5
Installer version: v1.3.5
Operating system: #1 SMP PREEMPT_DYNAMIC Wed, 21 Jun 2023 20:46:20 +0000 6.3.9-arch1-1
Catalyst license: none
Legacy editor: off
Plugins installed: 0
Plugins enabled: 0
Same as this?
Next/Previous Daily Note hotkeys does not work with subfolders - Bug graveyard - Obsidian Forum
Next/Previous Daily Note hotkeys should work with subfolders - Feature requests - Obsidian Forum
